Question about adjustable FPR and fuel pressure
1 Post
The new LR fuel rail that I installed came with a Fuelab adjustable fuel pressure regulator. I am also using a VDO 60 psi pressure gauge screwed into the FPR. The instructions that came with the FPR were to adjust the fuel pressure by running just the fuel pump and without the vacuum line in. I have Promax/Scivision MAF chips and their recommendation is to run a 3bar FPR. So, I adjusted the fuel pressure to 43. 5 psi which is the equivalent of 3 bar. When I turn on the engine and let it idle the needle reads a nice 43.5 psi. However, when I open up the throttle the pressure reading goes up to almost 50 psi.
Question:
Does a 3 bar FPR mean that the maximum fuel pressure will be 3 bar or does it only refer to the minimum fuel pressure?
Question:
1 Post
Originally Posted by OriginalSterm
3 bar is the differential across the orifice of the injector
Does that mean that I should adjust the fuel pressure such that on part open throttle the pressure gauge should read 43.5 psi (3 bar)?
set 3 bar with the vacuum line disconnected, this is static pressure. with the vacuum line connected, you should read something less than 3 bar at idle (whatever your idle vacuum is). with the vacuum line connected, you should also read your current boost level plus 3 bar (if boost is 15 psi, you should read 3 bar + 15 psi).
this maintains the pressure drop across the seat of the injector at all times.
Hey Man
Most AFPR and OE Bosch are rising rate FPR's that will increase pressure to compensate for the FP drop under load, That's how they are supposed to work. Yours seems to be doing fine.
1 Post
