Looking for difficult to find hardware
I'm getting tired of making a huge mess in my garage every time I drain the coolant system. I decided to start looking around for a stopcock that can be installed in place of the plastic drain plug in the radiator. I know for 87' and later cars the plug is M10 x 1.5mm and for 86' and earlier its M10 x 1mm. Problem is I cant seem to find any place that sells plastic drain stopcocks with a metric threaded end. I've checked Mcmaster Carr and a couple of other places with not success. Anyone have any ideas of where to look next?
I have drained mine a couple times now and all I do is disconnect the lower radiator hose from the radiator on the passenger side. Just loosen the hose clamp and pull it off with a bucket underneath it. If you do it quickly, there's no mess!
I looked and looked and looked and couldnt find anything. What im doing is a banjo bolt and fitting, with a hose going to a ball valve. Ill post pics once its ready to go.
I found a 2-way micro stopcock at Bohlender Chemical Supply, except its M8 not M10. If I can find an adapter to step up to M10 I'll be in business.
http://www.bola.de/E/Produkte/0F00055B.html
I'd like something like this. I just broke my drain plug two days ago putting it back in.
I had a big bucket, so the mess wasn't that bad, but I was doing it outside.
Hey Man
In all honesty disconnecting the lower hose is fast and does something a petcock can't do. It drains the system fast enough to bring any sediments out that tend to plate out when drained slow. A small matter yes, but if you are draining the system for coolant exchange or after a cleaning flushing it does matter to get the crud out quickly.
UAE Rennlist Ambassador
I found a stalinless steel plug for a 951 radiator at my local ACE HARDWARE.
Walked in with my core and matched up the treads tried it and it worked for me
no leaks....
Hey Man
Stainless steel and aluminum isn't a good combo...a non-metallic plug if you can find it would be a much better choice. I hope you glopped up the threads real well with sealant before that aluminum starts corroding.
Just a word of caution...remember metal/brass fittings expand at different rates that the plastic side tanks. I had replaced the plastic hose barb at the top part of the radiator with a brass one thinking it was better since the plastic one tends to crack. Ended up replacing the radiator after a few weeks since the plastic tank developed a crack at this fitting. Learned the hard way.
