Wiring Help on HKS EVC V/HKS Turbo Timer and PLX-M300
well i got me a heck of a deal today.i got a hks evc V, hks turbo timer and plx-m300 for $500.probably the only draw back is that i need to sell the hks ez II(basically an hks evc V without the display) thats coming in(i bought it off ebay before i got this awsome deal locally).anyways,i need help installing these.even though it might not be installed tomarrow,i figure i put the instructions with all the other instructions piling up with my parts.thanx in advance guys!
been a while since i tried to hook things up but now im at it again.right now im wiring up my turbo timer.i got the wiring diagram for the unit but i need help figuring things out.heres what i need:12v constant, 12v ignition,12v accessory,i know where the parking brake wire is, and 5v digital RPM signal.my unit is an HKS Turbo Timer Type 0,so if any of you guys wired up one of these please help.thanx for looking
I haven't wired one of those up, however the easiest way to find the connections you are looking for would be to use a continuity tester or test light and just start back probing stuff like the stereo connector with the ignition on until you find the right ones. I'm not sure what the EVC 5 requires but, I think my Blitz SBC required a 12v constant, 12v switched and ground which I found all on the stereo circuit IIRC.
