Psh, who needs 16valves to rev high
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Since the Tec3 drives its own ignition system it is the other way around – it is driving the coil packs so the tach signal is derived internally.
I haven’t seen this before! The only other possibility is that there is some serious noise (electrical) begin picked up by the crank sensor/wiring. Mike – I will chat with Fred (Electromotive president) on Monday - lets see what he says!
Chris White
BTW – on a complexly different note – there were two (!) 944 roadsters at Watkins Glen. Roof completely cut off with 6” tall windshields. Interesting!
Chris White
A 16-valve engine doesn't rev any higher than an 8-valve does it? Or is the idea that with 4 valves/cylinder the valves don't have to open as much, thus allowing the engine to rev higher before problems with the valve train occur?
-Darwin
Thefu
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Originally Posted by SeaCay
Been thinking of doing this myself to allow more cockpit room. Did they start as Cabriolets or where they hatchbacks? If the latter, how did they seal up the tail end?
As for valve float – the most common problem is the valves bouncing off the valve seats. The valves are closing so rapidly that the force of the stock springs is not enough to keep the valve from bouncing back open for a brief period.
16v heads can be made to survive at higher rpm due to the much lighter valves/lifters. Valve train weight is the main enemy of high rpm.
Chris White
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
You can rev a stock 8v engine past 7k rpm and it will not hand grenade. You will see greatly accelerated valve guide wear and no real power gains unless you change the cam and turbo. The 951 was not designed as a high rpm engine.
Chris White
Chris White
