Brake pad wear sensors -- has part changed?
I just ordered a new set of brake pad wear sensors from pelican for my '87 951 (with the standard 4 piston calipers) and received the part pictured below. The ones that are on there now contain two sensors per caliper (one for each pad, wired serially to the plug), vs. this part (951-612-212-00-M163), which contains one sensor per caliper. Is this what porsche now specs for our cars, or did these guys send me the wrong thing??
I can't help you. I've got to the point where I never hook them up anyway and find them to be a nuisance and hard to transfer between pads with breaking them. I have my wheels off so often I just do a visual inspection and pull the pads in under 60 seconds to really see whats going one. I never knew that the 87 had two sensors per caliper...and I thought just one was useless
Originally Posted by mwc951
When eliminating, do you just short out the leads to keep the idiot light from coming on?
KLR....sorry for hi-jacking your thread!
KuHL 951......I just replaced my torque tube. While the
rear suspension was down I eliminated all that wiring
for the wear sensors and shorted out the wires way up
by the fuel tank. Makes for a much cleaner sensor delete.
Why would you want to delete the sensors and leave
those connectors and all that wiring in place?
More over, how cheesy is it to zip tie the sensor itself to the brake line??
Sure seems like a no brainer to me. To each his own.
KuHL 951....more over, how cheesy is it to zip tie the sensor itself to the brake line??
OK -- I'm getting the picture that most people are shorting this circuit. Anyone know whether the part pictured above is usable for an '87 951 if one wanted to keep the sensor functioning?
KLR I had both kinds on my '89 when I bought it, and it worked just fine. I think I read somewhere that the one pictured above is the older style. Both kinds work, but the older style just monitors wear on one pad, and the newer style checks both pads, which is good if your pads are wearing unevenly. Like the others, I don't use them any more.
