Did anyone encounter this problem with the valve stem seals?
UAE Rennlist Ambassador
Cylinder head got a full rebuild, everything checked and double checked for wear limits and tolerances according to the manual.....new guides, refereshed valves, machined seats (and tested for leaks), adjusted springs etc.
Ever since the cylinder head rebuild, i have oil on spark plugs #1 and #2....i believe it is due to the valve stem seals....
I came accross this:
https://rennlist.com/forums/944-turbo-and-turbo-s-forum/62791-valve-guide-seals-not-staying-on-valve-guides.html
I ordered new seals from Paragon (teflon), the seals currently on teh car are from Victor Reinz, supplied with the cylinder head gasket kit....
Should the seal really be glued on the guides? i was sure to seat them correctly, but looks like some came loose.....
TIA
TIA
https://rennlist.com/forums/showthread.php?t=62791
TIA
TIA
Buck,
In my case, all spak plugs were dry before i removed the cylinder head. Now, plugs 1 & 2 are covered in oil, that link in the archives backed me out and i talked to a couple of vendors on this.
I would wait untill someone informs if any glue is needed or not.
Buck,
I always glue them now.
The factory ones I have replaced have all been glued. I have seen some stems that are smooth and some that have teeth on them. Most stems that are used now have nice grooves cut into them that allows the seal to bite in to.
Either way ....I glue just to be safe.
