CYCLING VALVE BYPASS
I'm installing a manual boost controller and would like to bypass the cycling valve. I think that in order to do this I need to run the other end of the manual boost controller straight from the banjo bolt to the wastgate tube.(So I have read) But where Do I connect exactly to this wastgate tube? I'm not sure. It is a jungle under there of vaccum lines and pressure fittings. Does anyone have any pictures or good descriptions? Also what do I have to do with the cycling valve after bypassed? What do I have to plug? It is over there by the entrance to the intake manifold on the mechanic's RH side of engine? with a curved boot sticking out
of the top of it? I'm not sure. I did a thread search and was having problems understanding some of the info out there. If anyone has pics who has done this that would be awesome and greatly appreciated. Thank You.
![Cool](https://rennlist.com/forums/images/smilies/cool.gif)
Hey Man
You'll find that most people here that run any kind of none OE boost control do a 'venturi delete' to simplify all those vac lines you mention. A search will give you all you need to know.
This diagram on the paragon website might be helpful http://www.tech-session.com/kb/index..._v2&id=117&c=4
I ran a line from the side port of my TIAL to the bottom of my MBC. I am using an inline pro MBC. From there to the banjo bolt on the Hard pipe coming off the turbo. I zip tied the MBC to the old capped off hard Line leading to the cycling valve. It actually made a nice place to mount the MBC. I capped the line in the J boot going from the MAF to the turbo. Works for me.
IPSC
![](http://img.photobucket.com/albums/v207/IPSC_GUY/Picture360.jpg)
![](http://img.photobucket.com/albums/v207/IPSC_GUY/Picture359.jpg)
IPSC
![](http://img.photobucket.com/albums/v207/IPSC_GUY/Picture358.jpg)
