Best way to seal OE sunroof permanently
Hello all,
Looking for the best/cheapest/most graceful way to properly close and secure my OE sunroof panel. My '86 951 is track-only, so I want to get the weight out. Since I'm endeavoring to do this on the cheap, I want to retain the factory panel (car has beautiful paint) but not necessarily drill holes through it.
Any ideas? The lid has to be secure, since if I ever do have a bad "off", I'd prefer it stay in place.
Cheers and thanks all!
Just make up some brackets and bolt it in. If you pull out the normal hardware you can use those bolt points with some very simple brackets and be done.
All you need is some thickish sheet aluminum. Probably 1/8" would work fine.
