UEGO 2000 question
Just got the UEGO A/F system. My question to anyone who has one is this. In the instruction manual it shows the digital readout on the display head with the squiggly line on the left and the straight line on the right (the line between the little buttons on each side). When I hooked mine up the lines are on the opposite side. I had to turn mine upside down ( according to picture). Is this right, wrong or no big deal?
Craig
Craig
My display has the squiggly line on the right side of the display and the straight line on the left, opposite of the instruction manual. Another words I mounted it per the manual picture where it shows the numbers of 14.7 and the squiggly line is on the left. After I mounted it and hooked it up, turned it on the readout was upside down. I turned it over so you can read the A/F ratio right side up which in turn put the straight line on the left side and the crooked line on the right side. It works fine I was just wondering if this is a mistake in the istruction manual or if the factory built it wrong. Also since I have not run the car and tried the little buttons on the sides they may also be wrong in there function.
