Fidanza flywheel torque specs
Im installing the Fidanza flywheel tomorrow. What is the torque settings for the pressure plate bolts? From Fidanzas web page I saw that the flywheel bolts are torqued to 74 foot lbs. It says nothing about the pressure plate bolts to the flywheel though.
Ted
89 Turbo
Ted
89 Turbo
Make sure that you double check the position of the reference point on the flywheel (and remember to locktite it in once it's set to the correct height). my fidanza was 2 starter teeth off (5.5 degrees) advanced. Car ran like !@#$ and pinged like there was no tomorrow.
Dal.
Dal.
