Looking for a bolt. (squealing problem) *WITH MORE nonconfusing PICTURES*
So today I put the car (1988 944 turbo s) up on a lift to see if I need to tighten the belt, as I was feeling around I saw that when I pushed a bit on the belt the compressor would move. (So im guessing the squealing noise is coming from the load on the belt moving the compressor which makes the belt out of allignment?) After searching around to see why the compressor is loose I found that a bolt is missing. Check out the picture, should a bolt be there?
thanks
thanks
Location: Albany, CA: celebrating 100 years of independence from Berkeley, CA
To be frank, it's a really bad photograph and I'm still trying to figure out what we're looking at. Is this from the bottom up, or top down? I'm thinking it's bottom up and you're actually pointing at the alternator rather than the A/C compressor....
More pictures
From the front of the car
Under, this is the unit which on the top of it, it seems that a bolt is missing so while the belt is under load this unit will move a bit from its position maybe causing the squealing.
The top of the unit where maybe a bolt should be
Yep same thing happened to me belts squeeled tightened belt next day belts squeeled WTF tightened belt next day same thing and p/s and a/c belt exploded from the piece of the sheared bolt getting under the belt thank god I have my belt covers or bye bye timing belt
I just wanted to show that I lost a bolt which was supposed to be there causing belt squeeling, you were asking if a bolt should be there
So I am correct about a bolt being there? Could I pick it up from the dealership?
It's a 13mm head, I think 8mm shaft, I forgot the thread probably 1.5 or 1.0 on the back of the AC compressor. The bolt on the other side of my compressor was missing and it ended up breaking the adjustment bar more than once and a bad squeal. REPLACE it ASAP or you will break the adjustment rod, there should be a 17mm head bolt in the front of the compressor.
thanks
Cool -- the additional pictures help. PET shows an M8x55mm bolt at the back of the A/C compressor. I believe M8 is 13mm head with 8mm shaft with 1.25 thread pitch -- commonly found at a typical hardware store that carries metric bolts. No nut, just a washer -- it must go to the thread in the A/C bracket.
