Load vs Timming (larger injectors)
Small Business Partner
When we use a larger injector and then 'hide' (MAF) the extra air in order to get the correct A/F, how much does this throw off the ign timming?
Does the DME use the VAF for its ign timming tables or does it look more at the TPS?
Rogue
Rogue
I have an aluminum flywheel without the second sensor so I can't check the timing values, but...
When I got the correct AFR with same as stock AFM/MAF voltages going to the DME I saw a 7 second decrease in 3rd gear full throttle run from 3000rpm to 6500 with 2 big dudes in the car.
The only difference in tuning was to tweak the fuel pressure and MAF voltage so I get the stock voltage range to the DME with the correct AFRs. My AFR's were the same throughout the rpm range for both runs. The only thing I know to attribute the difference in performance is that with the correct voltages the timing advancment is more accurate.
That was my experience with both Autothority and Lindsey chips.
I'm worried that by hidding all the extra air, in order to get a decent AFR, that the ecu thinks there isn't as much load on the engine, and doesn't use an accurate timing value...
Rogue
Rogue
Rogue
Rogue
Idle and WOT timing is purely RPM based so these are not effected, only part throttle timing is load dependant.
Drive-by provocation guy
So in getting readings you want to make sure you are at 4.7v at redline?
My concern is during normal driving or heavy accel, but not WOT.
If we are telling the ECU that their is less air entering the engine then what really is, then the ECU is going to be more liberal with timing, possibly too much.
Rogue
Rogue
Originally Posted by testarossa_td
Where is fast951 when you need him....
This sounds like a good tech discussion.
In this article (under 'caveman engine management') explains exactly what I'm asking about... Timing advancement because of 'hiding airflow'.
http://www.roadraceengineering.com/evo/scc-mrstg1.htm
There was also a very good read on SupraForums:
http://www.supraforums.com/forum/sho...light=piggy%2A
So do we suffer the same issues? Can I install 55lb injectors, a MAF & Piggyback, and not worry about unwanted timing advance? Or do I need a 'calibrated' chip to go with the injectors?
Rogue
Rogue
the best way to cater for larger injectors is to program the correct scaling factor into the FQS table. Four global fuel scaling settings can be programmed and selected between via the DME FQS switch.
Manipulation of the airflow signal with a piggyback then becomes purely a fine tuning exercise, rather than scaling + tuning with above mentioned part throttle timing issues.
The stock DME FQS settings are:
#0 -
#1 +3%
#2 -3%
#3 +6%
#4-7 as for#0-3 but with 2.7 degrees retard.
Aftermarket chips have more agressive timing and are typically setup for a 3 bar fpr, verses 2.5 bar on the stock chips.
#0 -
#1 +3%
#2 -3%
#3 +6%
