TURBO-PERFORMANCE(BAD)
#46
Quick question not trying to hijack the thread.
I have a K26/6 which sucked in a bolt or maybe sobatage it did not get injested into the turbo but it sheared off the turbines and is logged so the impellar does not turn can these guys repair it.
Norm
Norm
#49
Defending the Border
Rest In Peace
Rest In Peace
It can certianly be fixed. But what is more important is where did all the material from your impeller go? Trace the charge air path, inter cooler>intake manifold>head. If you find pieces in the head, purge your vaccuum lines. Look at the recirc side, waste gate>boost controller. If your crankcase pressures are off due to bad seals, they may have made it into the crankcase.
Look at how much material has been displaced (quick-large chunks, slow-far reaching slivers), and start at the intercooler. Hopefully, it "filtered" most of it.
FOD or DOD damage on a turbo car is typically not a cheap fix.
#50
The turbo was replaced already no damage the particles were too small, everything checked out intercooler is clean car boost and has power like it should. I was going to toss it when I saw the thread about rebuilding turbos and upgrading to a k27/6 that caught my attention.
What's the best source for a new or rebuilt wastegate..
Need more power.....boost is contagious
#51
http://cgi.ebay.com/ws/eBayISAPI.dll...e=STRK:MESE:IT
#56
Originally Posted by D944tech
Best wastegate around is the Tial 38mm, it runs you about $ 315.00 from my swiss another rennlister, the tial is not easy to install and may require welding, also good is the deltagate from Lindsey racing, which is a straigh replacement but it does cost $ 399.00 and requires a core exchange. For a much cheaper and easier alternative you can try shimming the wastegate like the following example;
#57
WTH? that's one of my auctions. The lart951 wastegates are guarantee to out perform the competition, many years of R & D were needed to produce this high level of technology.
#58
Rest In Peace
Rest In Peace
PHP Code:
