300whp reliable?
Old 05-17-2006, 11:47 AM
sweanders
sweanders's Avatar
Your welcome, it was one of the more interesting threads lately.
These cars are great since there are so many ways of upgrading and none is really wrong, and this board is full of people who document their mods. All fun.
I can't wait to get my car together, hopefully I will be able to test the Vitesse S3 kit in June.. It sucks having the car 650 km's away from where I am working..
Old 05-17-2006, 12:01 PM
WesM951
WesM951's Avatar
https://rennlist.com/forums/showthre...300rwhp+budget
Old 05-17-2006, 10:17 PM
buxton
buxton's Avatar
Thank you all for the help/advice. I will be making some improvements over the winter months to reach my goal. I am starting with a Tial wastegate and cat "test" pipe soon.
Old 05-17-2006, 10:29 PM
Driftomagnifico
Driftomagnifico's Avatar
Originally Posted by sweanders
Here you go:
I remembered wrong, there were some gains, 4 hp to be exact..
You can't bring a stock car dyno as proof that a 3" exhaust will not benefit a car producing 100whp more.
Old 05-18-2006, 12:21 AM
facboy
facboy's Avatar
A few weeks ago there was dyno proof that showed upgrading to 3" with stock turbo did nothing for power.
my emphasis :P.
Old 05-18-2006, 03:32 AM
944J
944J's Avatar
So why does vitesse say its 410hp if everyone here says its 300?
is it really 410 or not or is 20psi too much to run on a stock engine?
http://www.vitesseracing.com/Catalog.../stage_ii.html
and why get stage III if stage II produced more power?
Old 05-18-2006, 04:34 AM
sweanders
sweanders's Avatar
Correct, but on the matter regarding if a 3" exhaust will be beneficial for a car with a stock turbo it is of interest.
Old 05-18-2006, 09:36 AM
Duke
Duke's Avatar
If it's on a stock turbo or not is not the interesting part. It has more to do with power- and boost levels.
Acutally a stock turbo run at high boost might benefit from a less restrictive exhaust as least as much as a bigger turbo.
Old 05-18-2006, 09:46 AM
jgporsche
jgporsche's Avatar
Vitesse is not claiming 410whp on your application. This is just showing what the ST2 is capable of. The ST3 is capable of more.
Old 05-18-2006, 09:53 AM
JBrown
JBrown's Avatar
I just upgraded my car. New K27/6,55 injectors, LR waste gate, 3 FPR, Vitesse MAF, Greedy Profec b boost controller. I had it dynoed on a Mustang dyno and got 272rwhp at 15lbs boost. I had a bunch of vacuum leeks. I fixed the vacuum leeks and the car runs much better but i did not have it re dynoed yet. I have stock exhaust minus cat and a performance muffler. What kind of hp increase would i get if i did a 3" exhaust?
Old 05-18-2006, 10:02 AM
jgporsche
jgporsche's Avatar
like i said before, i gained 40+whp after switching to a 3" exhaust.
my mods:
Vitesse Maf kit, LR DP WG w/ MBC, 72# injectors, smt-6, LR 3" exhaust. i was running 15.6 lbs. of boost on my K26/6. *note* the run with the stock exhaust was @15.4lbs. My 3" exhaust does NOT have a cat or muffler.
I still have a little tuning left to do. So the next time i get back from the dyno, i'll post results.
Old 05-18-2006, 10:03 AM
eclou
eclou's Avatar
Received 1,226 Likes on 599 Posts
Full 3" with cat bypass would probably help you pick up 10-20hp. But get the leaks fixed and you should be able to crank the boost up to 18# - you should be close to 320 rwhp then. Just make sure you drill the AOS vent so you don't start springing leaks
Old 05-18-2006, 12:47 PM
JBrown
JBrown's Avatar
eclou, my airleek are all fixed . car runs great. Just kicking around if it is worth spending more money. If the gains are worth the extra HP.
Old 05-18-2006, 01:07 PM
mtnman82
mtnman82's Avatar
eclou, can you please elaborate on drilling the AOS vent? Springing oil leaks? As in from the seals, from running higher boost levels? And where do you drill? Thanks!!
Old 05-18-2006, 03:59 PM
944J
944J's Avatar
Doesnt the dyno read 410HP?
Quick Reply: 300whp reliable?
