Out with the motor!!!!!
I had my head off the car when I pulled mine, and just attached a hook to my broadfoot bracket (alternator) and then at the rear of the engine at that hook. You should be fine :^)
If you use a wide engine leveller, then the loop will not bend. It is only when you use 2 chains from a hook, or a similar setup where it is pulling at an angle on the rear loop that it will bend.
The front mounting point is much tougher than the rear one, and I have never bent one.
Jane Bond 007
Use a leveler and you'll be fine. I used the rings on mine. You going out the top or bottom? If top, get the leveler for sure. Trust me.
