New Turbo Alignment
Defending the Border
Rest In Peace
Rest In Peace
New Turbo Alignment
When I got my 27/6 conversion back, the compressor/body/hot sections were all loose. Because I will be installing the down pipe with the turbo already heat wraped, I won't have access to the body/hot section bolts to tighten after aligning in the car. Any suggestions on the best way of aligning these out of the car?
Because the compressor will not be wraped, I can align it in the car.
The mounting flange of the center section (oil exit) should be perpendicular to the turbine inlet flange.
The compressor section can be “eye-balled” to fit the orientation of the exit hose.
Laust
Laust
