What size T04E is everyone running?
Drive-by provocation guy
"63trim flows 75lb/min and is a 67mm Compressor Wheel. (basically a T04R shoved into a T04E housing ) For comparison's sake.. it flows 1088cfm at 1 bar"
That is the LR Super 75. I know it is 67mm comp wheel and mine is #8 hotside
Todd,
Yea the Lindsey Super 75 is the one you quoted. How laggy is it? This is what I was thinking about going with but was told it would be "very" laggy on a 2.5L.
I have full 19psi about 4,100rpm. So kinda laggy. But if you plan on doing anything to the top end, intake, heads etc., that might help a lot with spool up.
But my dyno graph is just like the one posted on the LR site; i.e. nice long, linear upturn and still making hp at redline.
So, lag isn't the issue, just need more revs!!
400rwhp and you are worried about lag? Maybe a GT35 at 20psi would do it. Probably turn out to be one of those cars you'd be bragging about how fast it would be... if it ran.
-Joel.
-Joel.
Joel,
400rwhp is my goal, but i'll settle for 350-375. I said "very" laggy.. not worried about some lag.. but yea 4100rpm is kinda laggy.
Todd,
Do you know what turbine wheel you have?
Todd,
Well Dan P made 360-370rwhp on pump gas, stock bottom end with a T04E 61mm compressor. So a 67mm compressor should get me there. A GT35R is a big turbo.. 82mm Compressor Wheel!
ross,
"56 trim flows 65lb/min and is a 61mm Compressor wheel." AKA Lindsey Super 65
hally,
I've been talking to pauerman, great guy. Most likely who i'll go through unless I can get a better deal elsewhere.. which I doubt.
hally,
>>>400rwhp. Stock bottom end (mostly stock top end) and on pump gas.<<<
Good luck mostly stock top end? Not going to happen. Take a look at ST Dyno run on pump gas 394 at 19-psi or My Swiss dyno run at 18-psi got made over 400.
Check the mods on those cars, far from stock. Lots of money to make that power. Not by only slaping on a bigger turbo.
