PS fluid hose replacements…What’s so special?
The hoses that connect to the power steering reservoir, what’s so special about them? Has anyone replace them with a stock hose? If so, what kind? The reason I ask is that my plan is to replace the PS system with a manual rack, but do not have the cash right now. In the mean time, I would like to stop the PS fluid from leaking and do not want to spend all that $$ on new OEM PS fluid hoes.
Any advice?
Randy
Austin, TX
Any advice?
Randy
Austin, TX
Any advice?
Randy
Austin, TX
Any advice?
Randy
Austin, TX
Check some of the local parts houses. Some of the NAPA's around here have the ability to make most types of hydraulic hoses. I would imagine they can repair/ remake the hose for less than a factory replacement.
ATF...really!
ATF...really!? You think that's why my power steering isn't working real well? The leaks appear to be isolated to seepage around the aforementioned hose ends. That is to say, the system hold fluid. I have the rack of right now, as I am rebuilding a-arms and some other stuff. Any maintenance that can be done to the rack, short of a complete reseal?...remember, my goal is to end up with manual.
