replacing BOV
replacing BOV
I have 2 951's, both with bad BOV's. I think they both have the original Bosch plasticjunk. I am leaning to getting Lindsey Racing valves. Has anyone had any experience with a company called Max Speed or EVO? Both cars are about stock except for chips and cat delete on one. Neither valve will hold vacuum and I have done vac hoses and venturi delete with Lindsey's kit and the throttle body with Bruce Arn's kit. Any help will be greatly appreciated.
Drive-by provocation guy
The 993 Bosch is good step up for only abour 30-40$ and for a mostly stock car.
Evo and Forge are also very good, but about 85-125$
I dont know about Evo, but I used a forge one for a while and found that it was prone to sticking occasionally causing loss of boost.
I then tried a bailey, which after a few thousand miles caused a vacuum leak... to which Bailey said "They all do that after a while".
I ended up buying a 9XX BOV from Jon Mitchell Porsche here in Bournemouth... Had no problems with it since.
We did a group buy last year, and haven't heard anyone complain ?
It was supposed to be a really good unit ( but it was a little north of a 100 bucks)
Regards
Ed
Get one of the 993 billet BOVs and don't look back. Just about any Porsche dealer will carry them. I bought mine from Don at EBS for like $118.00. It is a direct replacement for yours and works GREAT! ! !
IPSC
IPSC
Buy a HKS BOV for cheap off EBay.
They are a pull type so they don't leak at idle, and they work fine for cars running 1 BAR to 2 BAR with good amounts of airflow. They also have a sequential valve meaning it will partially open under light boost pressure throttle lifts, rather than being an on / off switch, which smooths out the transition back onto power in the next gear.
Lol, yea the site sucks right now for purchasing. If anyone needs one, PM me and i will take care of it directly. I believe right now i have 2 silver units on hand. Not sure if i have any black units on hand or not. $119 is correct. Actually, if you are a rennlist member we take 10% off that. Just PM me if you are interested in getting one.
Originally Posted by WesM951
Doc,
Cool, won't be right this moment as I have other things pressing. I'll shoot you a PM when i'm ready!
