Can i vent blow off valve to atmos.
Old 05-01-2006, 05:24 PM
cpt_koolbeenz
cpt_koolbeenz's Avatar
Bubb Rubb and Lil' Sis!
http://media.ebaumsworld.com/wmv/bubbrubb.wmv
WooowooOO!
Old 05-01-2006, 07:11 PM
Got Me a Porsha
Got Me a Porsha's Avatar
WooowooOO!
Did you see Bubb Rubb and Lil" Sis about take out that row of cars, and blow that stop sign?
Old 05-01-2006, 07:28 PM
Got Me a Porsha
Default GREDDY BOV
Does anybody have any information on the GReddy Type S BOV (the PURPLE one )? It came with the car, HONEST!, and causes it to load up on decel and stall. I cannot find any literature about it, but would like to try and make it work.
FWIW, it is really loud when it vents, but I dont know how long the transition from cool to annoying will take. It is a challenge to keep it quiet, and also saves gas in the process.
But, why purple? WHY?
Thanks in advance!
Old 05-01-2006, 07:40 PM
Zero10
Zero10's Avatar
Just curious, but should you be able to hear the stock diverter valve when shifting?
I've never heard mine, even when it was on the dyno.
Old 05-01-2006, 08:16 PM
FSAEracer03
TRB0 GUY
FSAEracer03's Avatar
Originally Posted by Eyal 951
Get a MAF. Lots more performance, you'll hear the diverter valve plenty fine, and you keep the advantages of recirculation. Just reving my car in the driveway with the maf building maybe 2-4 psi with the K26/6 it still sounds, and surprisingly loud for revving in the driveway.
Did you work out some anti-lag or is there some trick to making boost under no load that I don't know about?
Oh, and PS.... no, you can't dump the stock DV. It's an open system at idle, so the car won't run unless you blip the throttle.
Old 05-01-2006, 09:58 PM
Porsche-O-Phile
Porsche-O-Phile's Avatar
If it's building boost with no load on the engine, something is screwed up.
Old 05-01-2006, 11:45 PM
reno808
reno808's Avatar
thats how the old rally cars use to be run rich inbetween shifts to minimize lag..
Old 05-02-2006, 01:05 AM
FSAEracer03
TRB0 GUY
Well... I'm not sure if that's how they did it... but I know they use anti-lag to keep boost off throttle. Change the ignition to near-TDC exhaust and fuel slightly before it. Killer on the turbo, but keeps it spooling at high-boost.
Old 05-02-2006, 04:18 AM
schnellfahrer
schnellfahrer's Avatar
I get 4-6psi by just revving the engine in neutral.
Old 05-02-2006, 08:18 PM
Zero10
Zero10's Avatar
I stay below atmospheric when I rev in neutral
Old 05-03-2006, 06:59 AM
porshhhh951
Monkeys Removed by Request
porshhhh951's Avatar
boost is about load. Dont rev it once...rev it over and over again and you will see you start to build some boost even in neutral.
porshhhh951
do you have the stock AFM in place? do you have a test pipe?
My stock deverter valve became very loud after I got the maf put on my car. Before I never really hered much
Old 05-03-2006, 12:48 PM
mortymower
mortymower's Avatar
what exactly is a maf and what does it do?
Quick Reply: Can i vent blow off valve to atmos.
