XP: Crank oil seal will NOT come out.
I've tried using a screw, punch, anything I could think of but I am just shredding and putting holes in it. I've tried to deform it with a screwdriver and punch in order to get a piece of it bu nothing works.
I'm at my wits end on this one. I have never seen a seal so difficult to come out.
Any other suggestions?
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
not fully out - but you do have to undo the front bolts and it helps to lower it a bit (not completly necessary - but it makes lif alot eaiser when you put teh pump back).
Chris White
Chris White
So I managed to get it out. Unfortunately, I managed to score the oil pump housing area around the seal. The scored area is at the forward most section so I think that it can still seal well. I'm debating weather I should just replace the oil pump housing anyway as I would hate to reasemble this and have it leak.
