Is The TaTech EMS Being Sold In N.America or the U.K? - If It's "Plug & Play"........
then it would be nice to have another "plug & play" EMS besides the Wolf.
Does anyone know the price in USD? If not, how about a Euro conversion.
Little more info about tatech:
Demo program:
http://www.sohva.org/~tikkis/downloads/Tatech.exe
Tatech specs:
Ignition
Direct fire for 4 and 6 cylinder (5 and 8 cylinders with special order)
Distributor ignition for 4,5,6 and 8 cylinders
EDIS-module support (ford)
Ignition advance control accuracy 1 degrees
Adjustable dwell time
Ignition maps on 500rpm intervals 0-13000 rpm
30 load points / rpm range
Gear-dependent ignition compensation map
Fueling
Up to 6+6 high impedance injectors
Up to 4+4 low impedance injectors
Secondary injectors control based on engine load
Injector control accuracy 0,01ms
Injection maps on 500rpm intervals 0-13000 rpm
Gear-dependent injection compensation map
Compensation maps
Water temperature
Intake air temperature
Cold start / hot start / cranking maps
Throttle pump effect maps
Battery voltage compensation
Additional functions
Start rev limiter
Anti-lag system: adjustable activating point/mechanism
Gear dependant boost control
Water injection control, based on engine load
Closed loop knock sensor ignition control
Adjustable EGT-based enrichening and ignition cut point
UEGO (wideband lambda) support, UEGO-based autotune for fuel maps
(requires AEM / similar uego-controller; sold separately)
Mandatory sensors
Water temp sensor: 0 280 130 026 (Bosch)
Intake air temp sensor: 0 280 130 039 (Bosch) Turbo applications
Intake air temp sensor: 0 280 130 085 (Bosch) NA applivations
Additional sensors (suggestions)
TPS: 0 280 122 001 (Bosch)
HALL-sensor (rpm and Home) 1GT101DC (Honeywell)
Ignition amlifier 0 227 100 203 (Bosch)
EGT sensor: K-Type thermocouple
Knock sensor: 0 261 231 006 (Bosch)
Lambda sensor 0 258 005 706 (Bosch) 4-wire
MAP-sensor: 3BAR (GM)
Wideband lambda controller: 30-2301 (AEM)
I put info up, the first P&P kit should be ready within 2 weeks..
Demo program:
Tatech specs:
Ignition
Fueling
Compensation maps
Water temperature
Start rev limiter
Mandatory sensors
