Need some help-electrical problem
Okay, the car has been sitting a few weeks since I've been doing a little work on the door. I go to start it and no start. I jump it and it fires right up. I drive it for about half an hour and go home. I shut it off and and later checked it and it fired up. Now, It sat another three days and it was dead again. Now it won't even fire with a charged battery. It just cranks and cranks but not even a sputter. So I check the battery and it's draining about 1/2 volt every hour. I recharge it and disconnect the negative terminal and I get the same 12v dc from the negative post to the negative cable that I do accross the battery terminals. I have to go to work soon so I really don't have time to crawl underneath it today. I'm just looking for somewhere to start. I was thinking I have a grounded wire somewhere but I'm not a mechanic-although I will be after owning this car
you could have a cell in your battery that is going bad causing the battery to go bad - how old is it? If the battery is going bad, you can keep charging it but sooner or later that won't work anymore.
Keith
Originally Posted by david fracolli
Instead of pulling the ground off pull the fuses 1 by 1 until you determine what the cause of the battery drain is.
Does the door u were working on have any electrical equipement inside. Did you have this problem before u worked on the door. Maybe a wire is touching something ?
