Restarting engine after rebuild
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
The Smoke is normal – it will take a while to burn off all the oil and ‘stuff’ that got all over the outside of the exhaust / headers when you were working on the engine.
Belt whine is usually a result of an over tight belt.
Glad you finally found the problem and got it running!
Chris White
Chris White
Here you go. This should make you happier about your rebuild & initial startup.
http://video.google.com/videoplay?do...31999617693151
