Dyno Gain 2.5" to 3" exhaust
#46
I gained 31 HP on the dyno going from 2.5 without cat to 3 inch without cat - turbo back. Vitesse stock stage 3 turbo.
The gain is dependant on the capacity of the rest of the entire system. The k26/6 does not have the capacity to use a larger diameter exhaust on a 951 engine.
#48
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
BTW – interesting to note that at the highest RPM there was no difference – clearly showing that the turbo efficiency is the key limiting element not the exhaust. Turning up the boost further will not change that until the K26/6 is replaced.
The cat replacement does make a noticeable difference, even the cheap mild steel ones work fine.
Chris White
Chris White
#51
Is it possible the difference would be larger on a MAF equipped car, since that intake flow limitation would be removed?
This is great information to have, though.
#52
Drive-by provocation guy
After the instal, did you have to turn the boost down to get back to the same level as before?
If so how much?
So even if not a lot of hp/tq gain at same boost levels, if the turbo is working more effeciently, i.e. you saw 2,3,4 more psi at same boost settings, then that is a good thing.
If so how much?
#53
boost went up by nearly 5psi...I'm not really sure, I had to let off, as when I saw 20psi I got scared.
Yeah turbo runs soo much more efficiently.
MAF + open exhaust = happy turbo
#54
If so how much?
If so how much?
#55
3" exhaust upgrade
Just curious, which magnaflow muffler are you using? I have a Borla installed on my stock 2.5" system from the PO, and it is too quiet to hear the motor on track days with the windows down.
Thanks,
Dave
Thanks,
Dave
#56
