90° fitting for Bailey DV30
Where the heck do I find these suckers? Bailey motorsports Part No: PE01 (90° Plastic 1/8" BSP D.V. Top fitting) it can be seen here...
http://www.msport.co.uk/acatalog/inf...24%5f72%2ehtml
All I can find are NPT threaded barb fittings...
Thanks...
Thanks...
Originally Posted by theedge
Tried there, all they have are NPT (National Pipe Thread) fittings I need BSP (British Standard Pipe) which is 18 threads per inch instead of 17? on NPT fittings...
any other sources?
any other sources?
any other sources?
Defending the Border
Rest In Peace
Rest In Peace
Rennlist Lifetime Member
1/8 NPT = 27 threads per inch
1/8 BSP = 28 threads per inch
Does it call for BSPT or BSPP? If BSPT (taper) you can get by with a 1/8 NPT thread. If it doesn't specify, its probably tapered.
A good tap and die set will solve your problem. Buy a standard 1/8-27 NPT fitting and chase the threads with a 1/8-28 die. Use a small amount of green loctite and you are good to go. Use the loctite sparingly, a drop will seal the fitting.
this Rennlist is proving to be a valuable resource, I'm going to have to pony up for a membership soon...
thanks guys.
green loctite??? I've only seen blue and red? does the green stuff have a number??? i.e. 262
jason
