ProMAX SciVision MAF - even more stealth!
Legend Killer
the computer part......I allowed the wires to get too close to the alternator and they got tore up...in the process the computer was shorted..........
Andrew is normally very good at communicating through email, but have you tried calling him first thing in the morning US time? It will be early afternoon here.
Hi Roger,
I have just returned from 2 weeks in the USA. I have e-mailed SciVision again (yesterday). This was also copied to yourself.
SciVision confirmed they had repaired your damaged MAF computer before I left. I am very disappointed to read that this has still not been resolved.
I will phone SciVision on Monday (they will be at the race track this weekend) to to see where we are with this.
Have a good day!
Regards,
Andrew
Have a good day!
Regards,
Andrew
Originally Posted by tommye
Andrew,
Any more news on the 1.2 Bar set-up ?
Any results from the tests ?
Any new dyno runs ?
And,
-Are the SciVision chips intended for use with 3 Bar fuel regulator ?
-I understand that original, shimmed wastegate is what you recommend. What about original WG with harder spring or Tial WG ? If I understand right, at full boost at peak power the system operates beyond max scale of the MAF (?) and fixed tables are used (?) So, the type of WG used must be important.
Cheers,
Tommy
Any new dyno runs ?
And,
Cheers,
Tommy
I've been away for a few weeks in the USA. Sorry I didn't see your message sooner.
[1] 1.2 bar set-up has been developed. I am awaiting for SciVision to confirm when they have addressed the copyright protection on their software.
[2] No new tests and dyno runs other than those carried out by customers.
[3] 3 bar FPR is recommened for use with SciVision chips along with shimmed wastegate (depends on condition of original).
[4] Wastegate just needs to be able to hold 1.0 bar boost (to the red line). Only single port wastegate can be controlled by cycling valve and KLR.
All,
The SciVision MAF kit is $999.95 including shipping to USA/Can. This fit and go MAF system requires no set-up, is totally stealth (retains standard airbox) and has passed CA visual and smog tests. It is recommended for standard cars (if using the optional Scivision chip set) and also cars with mods (FPR, Dual Port Wastegate and Chipset). We have seen 370bhp in the UK (tested at Thor Racing) using the MAF kit with 55# injectors, LR Super 61 turbo and 1.25 bar boost (also using the standard airbox!).
Regards,
Andrew
Legend Killer
Originally Posted by promax_motorsport
Hi Roger,
Have a good day!
Regards,
Andrew
Have a good day!
Regards,
Andrew
Thomas at Scivision finally advised that they sent my repaired MAF back via DHL, although he did not give me a tracking number which I requetsed for a couple days ago.
Legend Killer
Originally Posted by Diver944
Before the alternator damaged the wires how was your setup running? Your 2.8 with K27/6, TiAL and 3" exhaust is far from a standard car, did you need custom Chips?
Originally Posted by JDeitz951
marcoturbo,
What does "Guru/promax chips" mean in your sig?
Promax used to sell Guru chips (without remapping them, I even get Guru decals on my chips), I beleive they no longer sell them.
