Airbag light reset - can't find molex connector
Title pretty much says it - I'm going to try resetting my airbag and seatbelt lights with the Clark's procedure, but I cannot find the damn molex connector. I spent half an hour on my back looking around for this thing to no avail.
From what I've read searching the connector itself is white and should be just hanging behind the glovebox. Has anyone had to remove the glovebox to get at it? Or might it be hiding behind the wood panel in front of the DME/KLR?
Any help/suggestions appreciated.....
it helps to have a second person and a good stop watch or precise second hand. Took me and my wife three tries a couple of years ago but we got it.
what year car do you have? IIRC, you ground the plug for 5 seconds(certian pin), off, on, off, turn key off - or something like that. Is it the 89 cars that have to have the reset tool, like the 968?
I was able to reset the light in my '89 using the ground, key, ground..... method. A length of wire stripped on both ends (grounded to the door striker plate) worked for me.
Originally Posted by jerome951
Mine was attached to the top of wire bundle behind the glovebox. Took me a while to find it as well.
Does anyone know what size pin connector will fit in there, or has everyone just used bare wire?
