Does Anyone Know How To Install Safety Wire????
I geuss I overlooked the fact that they are not available in metric sizes, but here they are anyway:
http://www.mcmaster.com/param/asp/ps...=scs;110=48015
Since I'm already playing the linking game, for anyone that needs hardware for a 46 mm, this is whats needed:
4 of these (come in a box of 10): http://www.mcmaster.com/param/asp/ps...2662;136=40008
4 of these (come in a box of 10): http://www.mcmaster.com/param/asp/ps...2662;136=40049
I don't think I need to wire. It looks like you guys are wiring the adapters to tial bolts on, and not the flange bolts. Since the 46 has no adapters, I think I should be ok with loctite and locking washers.
Eyal
Eyal
oh thats right, you can't link McMaster pages...
OK, start on the home page scroll down, close to the bottom, find the main category "Fastening and Sealing" In the list under this category, find Socket Head Cap Screws and click on it. From there I think you will be able to figure it out. For anyone that needs 46mm hardware dimensions, here you are:
4 stainless steel M8x1.25x20
4 stainless steel M8x1.25x26 (M8x1.25x25 is what I ordered)
Eyal
Eyal
Originally Posted by macnewma
I don't know how many miles you have on yours, but mine has come loose a number of times. I have tried a few different solutions and I will be using safety wire soon.
Originally Posted by pk951
I have driven quite a few miles and had not one bolt loose or fallen out.The wire is a good idea for not losing the bolts, but it wont stop the bolt from losing.. Thats why you have to go through a couple of heat cycles of retorquing. I used foot long pipe over the ratchet, and tighted the bolts that way. Those bolts must be on there more than a few FT-LBS.
Originally Posted by Eyal 951
yikes, you wont be happy if you break the bolt that way, carefully with that!
theedge can you please explain to me how does that type of safty wire kit works. I am very interested. in it. I want your input on it..
Defending the Border
Rest In Peace
Rest In Peace
That kit works if you are using hexhead fasteners because the tabs wrap around the wrenching flats. It's a quick fix but not as mechanically secure as lock wire.
And obviously won't work on round headed fasteners.
![ooops](https://rennlist.com/forums/graemlins/icon501.gif)
Sam
