Update for work in progress (kind of long and need tips)
UAE Rennlist Ambassador
Just finished removing the cylinder head, all went very well.
Now, the reason for changing the headgasket was that there was an oil leak coming from the cylinder head gasket, it's the original 20 year old one.
Now, when i removed the cylinder head, the gasket was stuck on the head, and not the block. After removing the gasket, i didn't find any signs of the regular wear i see here (holes in the gasket here and there). The gasket is thin, very thin, but i was quiet suprised it lasted this long, heck i think it would have lasted another couple of years
Anyways, i got a straight bar and a 0.05mm feeler gauge, i found no bends. But the head is going to the machine shop for repalcing the guides, checking the springs, valve lapping and so on, they will check the head for being flat.
The bores on cylinders 2 & 3 are perfect, absolutely perfect. No scores, no marks, nothing, just a clean shinning wall.
Here is the deal, when i removed the cylinder head, some sand/dirt fell into the bores and cooling area for the block. The cooling area is no big deal, since the coolant will be flushed, but how can i remove the dirt (minor IIRC) in the bores?
Basically, i saw some people who would sand down, or remove carbon deposits on the pistons, how would you remove them from the bores?
I will NOT turn the crank to check bores 1 & 4 (since they are at TDC) and risk having dirt get stuck between the rings for pistons 2 & 3, tips would be MUCH appreciated at this point.
One note, there is very little carbon deposits on the pistons and the combustion chamber, so that is another good sign, but i really would like to remove the dirt in the bores before turning the engine.
Pics will be up shortly (people love pics )
Originally Posted by AL951
I would'nt worry about it. just get some compress air and blow it off.
Regards,
AL
Regards,
AL
Upon further investigation, i do have some score, very minor ones. They are so minor that i couldn't see them yesterday, no i can't feel them with my finger nail, so i am not worrying about it (i knew the bores were good, since my oil consumption was very low). But i know why those scores are there, when changing the spark plugs (a while ago) some dirt fell into the combustion chamber, i got lucky, i have seen serious damage to bores from this.
Now you know why i am over reacting to this
1 Post
Originally Posted by mark944turbo
vacuum cleaner? I think you are overreacting about a little dirt, but it is good to be careful.
Even as westernized as Dubai/UAE is there is no changine the geographic location! We're talking baby powder kind of sand...the stuff gets EVERYWHERE!
Originally Posted by guns951
Have you ever been to Dubai? If you take a picture with the flash when the wind (very insignificate breeze) is blowing your pic is filled with reflections of sand floating in the air! ITS IN THE DESERT!
Originally Posted by special tool
Hosrom - did you remove that head yourself?? I don't believe it, boy. Post some pics.
Much respect if it is true.
I lost my camera a few months back, really wish to take pictures and post them (it is amazing how much space there is when everything is removed). But i will find a camera to borrow from someone around here.
Oil cooler seals, front engine seals and lower balance shaft cover (and real balance shaft seal) are still on the agenda since the head is off, as well as a full rebuild of the cylinder head itself. Not to mention, some polishing and (maybe) painting going in there as well.
Guns: Let me know when you come by, the drink is on me, you are in MY town
