Stock car + LBE + Tial 38 = Any good?
Hi guys!
I´m offered a lindsey boost enhancer at a good price and wonder if it will do any good in my stock car with a Tial 38 wg?
I want fast spoolup since i plan to do alot of autox and stuff.
The car is a 87 951
Will they work together? Since i'm stock, will I still experience the boost spikes i've read about?
/Peter
The car is a 87 951
/Peter
If you want to reduce spoolup time you would want to get a set of chips mapped for a MBC and the Tial, then get rid of the cylcing vavle. The cycling valve is what slows up the response.
I'm sure if you want, it is not ideal but can work. Just disconnect the cycling valve and run the LBE directly to the WG. Once again, this is not ideal but it works and you will feel the turbo come on much earlier.
I don't want to raise the boost with the lbe or chips, just reduce lag on the stock engine.
is this possible with the tial and lbe together?
My engine burns oil so therefor i'm wating for more upgrades til next winter when i'll rebuild it.
What does the cycling valve do and where is it?
The second tip, is this risky in any way? What would be the effect of this not ideal procedure?
/Peter
/Peter
/Peter
/Peter
The LBE will reduce spool up slightly. If you are already having some issues (burning oil), I wouldn't recommend making anymore changes until you can fix it. However, set for stock boost, the LBE will make a small noticable difference.
SciVision KLR/DME 1.0 bar chips
Hi guys!
The car is a 87 951
/Peter
The car is a 87 951
/Peter
We can provide a safe electronic solution to fast spool up using a single port wastegate (or Tial 38 in sp mode). The SciVision KLR/DME chips simulate the boost enhancer effect by switching the cycling valve to block the air signal to the wastegate and allow boost to build to 1.0 bar. This is similar to the effect of a Dual Port Wastegate but with the added security of the factory overboost protect and knock detect.
These chips are designed to exploit the SciVision MAF solution but can be used on cars with AFM too. It is recommended to use them with 2 wastegate shims (2mm) and a 3.0 bar FPR. Can be used with 2.5 bar FPR, but power will be limited.
The chips are good for at least +35bhp and 50lbft torque and significantly reduce turbo lag (300bhp with SciVision MAF kit). Also - no boost spikes as you retain full elctronic control as Porsche intended! NOTE: The standard software limits boost by venting the air signal to the wastegate dropping maximum boost from 0.75bar to 0.5bar by 5,000 rpm (on 220 cars). The standard software also switches the cyling valve to slow the build up of boost - hence the lag.
All these issues are properly addressed with the SciVision chipset. Coming soon will be a 1.2 bar chipset with 1.5 bar KLR MAP sensor mod!
Regards,
Andrew
www.promaxmotorsport.com
Last edited by promax_motorsport; 03-08-2006 at 10:22 PM. Reason: SciVision KLR/DME 1.0 bar chips
