Parts all on
Parts all on
Well got my car back with all the mods done. Not going to go thru them i am sure you guys have seen my other post. Anyway get up early thismorning to take a nice long drive and break in the new turbo. Drive about 30 miles and decide to stop. I open the hood and start the car to see how everything is. Looks ok. So i turn the motor off. When i do that i hear a funny noise coming from the turbo as it spools down. Go back to my mechanic, pull off the intake boot and look at the cool side compressor and the nut that holds it on is missing and the fans are all chewed up. found the nut in the intake tube. Thank god i was not boosting and sucked it in the intake ( if that can be done ). So end result, need new turbo ( this one making all kinds of noises) and 8 or so more hours to my mechanic to swap it out. My day sucks. My wife says, told you to leave the car alone. Oh well now i have to wait intill next thursday to get it swapped.
Thanks , This is a new ( rebuilt ) that is under waranty
that happened to my old K26/6. It tends to happen if your getting pops through the intake, or your diverter valve is no opening. It slows/stops the turbo so quickly that it will loosen the nut. You may just be a victim of a bonehead with a wrench, but I'd check on it just to make sure. you didn't have any running issues on that drive did you (lean specifically)
You probably have some clean up to do. I had to remove every singel piece of intake to the head and clean em... then I had to do it again.
Eyal
Eyal
I recently saw an article that said there are 2 different thread types of k27 shafts. ccw and cw. They had problems with wheels coming off so they reversed the threads. Make sure yours counters the compressor rotation.
Basic Sponsor
Sorry for my ignorance but which nut is the one that gets loose?
The car runs fine. I was breaking in the turbo so never went under boost. This is the second one out of 3 turbos that i have bought that did this. The first one was on my 911 turbo. Just rebuilt top to bottom motor and the nut cam off and jammed in the wheel and seazed up the turbo. I am very **** after i get some work done so i was babing the car and caught the problem early .
JBrown, Sorry to hear this. Make sure you have the K27 7200 series compressor..
Clean the IC, IC pipes, Intake.. Also do a leakdown on the engine just to make sure nothing went in..
Basic Sponsor
Originally Posted by Eyal 951
center of the compressor, there is a nut. find a compressor pic, and you will see it. or you prolly have turbos lying around, check one!
