More on my throttle problem
I would suspect your throttle body shaft leaking air at WOT. Does the shaft feel snug inside the throttle body ? U might try carefully spraying it with some quick start while your cold engine is idling and see if it gains rpms.
Did you check your IC hoses. Sounds like you blew one off or one is cracked. I've had that problem before. It goes with out saying that you need to check all of your vacuum lines.
Rip IT, when I rebuilt my TB I had seals cracked and falling out and never had this problem.
Originally Posted by five-o
I guess it's going to be a process of elimination. I was hoping someone else may have had this problem in the past. Well, if I ever figure this out I'll let you guys know. Thanks for the input.
How much does a coil, wires, distributor cap, chips, afm,fpr cost $1000 ???
It 's amazing how much trouble a simple air leak can cause
