crankshaft difference??
is there a difference between a 944 crankshaft and a 951 crankshaft..
I have the opportunity to pick up a spare never used 944 rothmans cup crankshaft.
thanks...
thanks...
I disagree that there is no difference.
The 1983 cranks are about 2mm shorter on the nose since they had no power steering pulley. If you build an engine w/ one of those, you will have to center the pulley by trial and error or build a spacer - guess how I know that.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Matts right - the early na cranks are shorter - but will work just fine for nonpower steering cars. Other wise the rest of the crank is identical.
Chris White
Chris White
Chris White
Chris White
Did not know that. Is it a different part number? Any easy way to identify a short one?
thanks for the help guys. It is a rothmans cup drilled crank still in the box.
944 037 011 22 part number...noticed this part number is different
from the ones listed above
If you look at any of the specific Turbo Cup and Club Sport part numbers, they will just have a different revision/superceeded suffix than the stock part (ie 951 XXX XXX 05, instead of 951 XXX XXX 03)
Also, the Rothman's 944 n/a's were just street cars that the dealerships involved with the series modified for racing. They really were not a factory motorsport version and did not use anything special as far as high performance components.
Even the factory Turbo Cups and Club Sports did not have a different crank shaft. So I would be carefull about paying more for this "Cup" crank than the going rate for a stock crank.
The crank it is being sold very cheap.. woops the part number i put down was wrong it is actually
#944 347 011 22 it is a new cross drilled crank...
does this part number match up...
So the crank is not in the original box. Factory didnt cross drill any cranks, so its had some work done on it. But if the price is right, and you need a crank....
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Oddly enough – I have an early cross drilled crank too. I bought it from PorscheNA when they moved their HQ. Came in a complete engine (with high comp pistons)…no history or explanation!
Chris White
Chris White
