Just got my 951. Question?
I bought an HKS evc 5 about a week ago so i'll be putting that in and will try to pull the cycling valve out. Also I went to emissions today and failed. I guess i'll get a new O2 sensor, spark plugs, wires, cap and rotor. I also have the cup chips installed. Will that make much of a difference.
-Destin
-Destin
Lifetime Member
Lifetime Member
Make sure all your vac lines are in order or no chance of running properly. Since your cycling valve is (apparently) out of the loop (like mine), this is the diagram you want to use:
http://members.rennlist.com/jerseysh...51_vac_new.jpg
Lifetime Member
Lifetime Member
And here's the original setup:
http://members.rennlist.com/jerseyshore944/vac4.jpg
If yours is somewhere in between, you better get it sorted out.
