Atte. Special tool, Help I want to lighten my car, UPDATE LSD TRANNY IS GONE
Basic Sponsor
Originally Posted by M758
lart... what do you consider streetable?
How much are you willing to spend?
My 944 NA is 2450 with a full roll cage and could be streetable if you did not care about the noise. It was cheap to do. You can lose weight via fiberglass too, but that costs more.
What about the power windows can they be converted to manual?
Joe, you also asked how much I am willing to spend. Well let me see, a new cam, larger, injectors piggyback and chips would give me a another 30-40rwhp the cost is around $ 2200.00. Maybe I have an extra $ 1500.00 to spend
Luis, are you wanting interior stuff removed - insulation and stuff? Widow regulators, glass?
click on the track car link, JAB racing and take a look at the items removed. Now, had we left the headlight and turnsignal stalk, I guess it would have still been streetable, brake lights do work. Anyway, the track car weighs in 2552# with 1/2 tank of 104.
All insulation/carpet/interior trim/ gone, door glass/regulators gone, air bags gone, blower motor/heater core gone, fender liners, cruise control brain/solenoid, headliner/sunroof interior panel, all headlight items, washer tank, water cross over pipe, A/C delete bracket lt weight s.s. exhaust system - this was MY 87.
Basic Sponsor
yes, but there are great write ups on it if you haven't done but with your parting experience, I don't think that will be an issue, time consuming but not an issue.
I tell you what, getting 500-700# out of these cars, when you get in the boost, it's like a damn light switch!!!
Basic Sponsor
I wil be changing my screen name to 951-junky l
Ok, I know it has been said before, but I can't find it, when you remove X amount of weight is the same as adding X amount of power to the car. I can't remember what the factor is because when I go down this road it helps to justify lighter VS cost to get more power.
I think the lbs/hp ratio is 17.68:1, lbs/tq ratio is 18.12:1. So, if you cut 400lbs, you would effectively gain 22.6hp and 22.0tq.
Also, keep in mind that doesn't factor in the improved handling that you will also get, plus the ability to add strategically-placed ballast if you are under-weight for a certain competitive class.
one thing I MUST state clear: The internet page I refference to is NOT MINE !!! Somebody else spend all the time collecting this very valuable information. He realy did a fantastic job.
My only achivemnt was to post the link because it fitted in the context. There are only the few remarks from my side which I posted because I ran through the same process twice.
Originally Posted by MPD47
Lart, here's a list of what I've done weight redux wise.
Koklen Rear Subframe
AIR Splitter
Lindsey Racing Stage V Nose Panel
Popup Headlight delete
GT Racing Slim Rear Bumper
GT Racing Fiberglass Fenders
GT Racing Fiberglass Hood
GT Racing Fiberglass Bumper cover
968 Hatch Trim
968 Turbo RS Adjustable wing
Lexan Hatch
Stripped interior
Sparco Pro 2000's
Lindsey Racing Exhaust
Manual Sunroof
Manual Mirrors
Gutted Dashboard
AC Delete
Power Steering Delete
Ripped out most of the stock wiring
I cannot give you individual values per item nor can I give you a final weight right now, but I'd venture a guess mine weighs less than Jim's. Personally I'm skeptical of his 2510lbs till I see some pics/mod list/photos on a scale. I'm guessing when I say I think my car is ~2550lbs.
AIR Splitter
968 Hatch Trim
Lexan Hatch
Stripped interior
Sparco Pro 2000's
Manual Sunroof
Manual Mirrors
Gutted Dashboard
AC Delete
Joe, what weight redux stuff do you have?
A/C, heat, headlights, heat shielding between engine & fire wall... basicly everything that was bolted or glued in. Only "replaced" item was manual steering vs power rack and two race seats & harnesses.
Originally Posted by lart951
Joe, I really don't care too much about the way the interior looks or even noise, my wife don't like the car anyway so I ussually drive alone. Lexan windows and hutch would be ideal, but I don't think that they are street legal in California, also I am planning to remove the carpeting and pading, install the Ac delete kit.
Driving a stripped car on the street with a bare metal interior is not very fun thing. Car gets very loud since any noise resonates through the interior. A light carpet would probably help alot as it would absorb some sound other wise bouncing around.
For me it is a race car and track car so I don't give darn how loud it is inside the car. I did car greatly about cost so that drove most of my weight redutions. Really the car is probably abotu 2400lbs if I pull the 40lbs of ballast and the passenger's seat. I also am running a full size battery so you could run 5-8lbs lawnmower batter or similar and save some weight (I think there was tread on lightweight batteries in past few months with all the details).
Basic Sponsor
UPDATE, UPDATE; I just broke my 89 944 turbo lsd transmission, I was on the fwy early this morning and did a 2nd gear pull and kaboom and right away a loud rattleling noise came from the tranny, at first I thought it was the clutch but when I pressed down to disengage the clutch the noise stopped and as soon as I release the clutch to engage it, even if the tranny is in neutral the rattle noise comes back.. I think it is the 2nd gear on the tranny, that's what I have been able to diagnose. I have disengage the coupler between the tranny and the torque shaft and if you manually rotate the torque shaft from the clutch it runs smoothly but when you rotate the tranny shaft it grinds a little and it doesn’t rotate smoothly as it should..
