Dyno Results on my K27/8 + Vitesse MAF
Old 02-15-2006, 12:13 PM
Mike1982
Mike1982's Avatar
Keep this going, I have a oil leak from my turbo I need to put it and check everything, but if I am going to pull everything out, I am going to upgrade. Leaning towards the K27/6 but would like a K27/8 in there. With the upgrades I already have and would do with the turbo, it would spool almost if not faster then a stock K26/6 turbo 951.
Old 02-15-2006, 12:15 PM
hosrom_951
UAE Rennlist Ambassador
hosrom_951's Avatar
Originally Posted by jimbo1111
Hay Hosrom? Is that a dyno of your car? If memory serves that guy Shane runs a 2.8
Shane's 2.5L with K27/8 turbo
Old 02-15-2006, 12:20 PM
951TurboEuroSpec
951TurboEuroSpec's Avatar
Im glad to see someone try this combo as this is what i have wanted. I have wondered how the vitesse hardware would wake up a k27/8.. im planning to run at 18psi so should be close to the 300 I have planned...
Old 02-15-2006, 12:23 PM
shane rizzo
shane rizzo's Avatar
Hello, this is shane. that dyno run is from my car. its a 2.5l it has a lots of head work, cam etc. stock size vales. k27/8 stock muff and the berch test pipe, 46 mm WG, 52lb injectors and some other small stuff.
Old 02-15-2006, 12:30 PM
jimbo1111
jimbo1111's Avatar
Nice dyno chart. Who's cam and was it a real 20psi run?
Old 02-15-2006, 12:51 PM
shane rizzo
yes it was at 20 psi. the cam was custome made by elgine cams. cant remember if my fuel ratio is on that sheet on the first page but, it was very, very rich. like off the chart.
Old 02-15-2006, 01:23 PM
jimbo1111
jimbo1111's Avatar
Sorry. A little OT. Was your run done on the stock clutch?
Old 02-15-2006, 01:32 PM
shane rizzo
kind of. stock pressure plate and s cup disck. stock flywheel. stock pistons, carrilo rods, stock crank. Im also using a manual boost controler which is mad by tubo xs.
Old 02-15-2006, 01:46 PM
sweanders
sweanders's Avatar
This shows how important it is to show all components when posting a dyno sheet instead of just posting it with absolutely no usefull info.
Old 02-15-2006, 01:52 PM
pk951
pk951's Avatar
A little ot what chips were you using? nice chart.
Old 02-15-2006, 02:00 PM
hosrom_951
hosrom_951's Avatar
Originally Posted by hosrom_951
At 18psi one should be seeing 310-340rwhp with MAF/MAP, wastegate, exhaust and usual 'bolt ons'
I wasn't informed of any modifications on the cylinder head, but that doesn't give an excuse to start something. Looking at the thread and posts, the only 'issue' discussed was if it Shane's car was a 2.8L or a 2.5L.
Old 02-15-2006, 02:25 PM
jimbo1111
jimbo1111's Avatar
Point is. A maf and turbo alone will not produce those numbers. As you can see he has a freshly built motor (means alot) with headwork/cam and a semi upgraded clutch. I had that car confused with shane in cali. Who has a 2.8. with similar output. HP isn't cheap.
Old 02-15-2006, 02:35 PM
shane rizzo
I am in calif but, the car is a 2.5L. it has fresh rings well they have about 20k miles on them. my head had D shaped ports, chevy valves and aftermrket valves springs with titaneum retainers. I am using the wide fire gsk, o ringed head. standard mass air 75mm with chips. 52lb injectors. most of my internals such as piston top, head chambers, valves are ceramic coated. stock exhaust system other thabn a birch test pipe.
Old 02-15-2006, 02:46 PM
UK952
UK952's Avatar
Well for comparison my car with AFM, K27/8 (with some mods, not sure exactly what but 360 thrust bearing rings a bell) 55lbs injectors, guru chips, Profec Bspec1, FPR, Tial running just under 18psi IIRC, AFM, essential styling exhaust, dyno dynamics BOV, small boost leak somewhere produced these graphs last year, 329.1flywheel 278.9rwhp
http://www.cannell.co.uk/DD%20H419NHP.htm
(thanks Rick)
Engine over 150000 at time of run.
Those were not the best set of chips I ran, the 15 psi ones were much closer for fuelling - but no runs on a load dyno, so I only only have overly high graphs in earlier configs (before EBC and injectors).
MAF will be my next mod, but currently my head is off awaiting new valves the old ones had worn stems. Guides, light skim and casting clean up are also on the menu.
Tony
Old 02-15-2006, 02:51 PM
jimbo1111
jimbo1111's Avatar
Thanks for the info. The reason I asked about the clutch is because my stock clutch gives out at around 350 whp. I knew it wasn't a stock clutch you had. I can also bet that the headwork you have is giving you 30 to 40 rwhp. Do you agree?
Quick Reply: Dyno Results on my K27/8 + Vitesse MAF
