Custom vented nose panel pics
#31
Originally Posted by TurboX
I don't see why people are hating because he made the bumper look different ![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
#32
That Guy
so what about people the buy Mille Miglias which are much heavier than stock wheels, that would only be a visual upgrade, and would not serve a performance upgrade at all? I don't see why visual upgrades are bad.
How can you say it doesnt help cooling, he gets twice the air flow through the radiator!
#33
As I said, in a stop and go environment, you are much better of with a vented hood, to allow the ambient heat to escape as it rises.
At speed, if the air were directed properly through ducting in and out, it would then serve as an improvement to cooling.
#34
If were to travel consistently say between 130 and 150, then I would need to worry about convection in the hood or trapped air. Plus the opening does not hurt the drag coeficient in the car, on the contrary, it more than likely lowers it if anything, if you really wanna talk about aerodynamics, then let's talk about how much lower MY drag coeficient is going to be driving at night with no pop-ups as opposed to all those with. The bigger inlet can actually supply more air than the two little fans in front of the engine, with less stress.
#35
Plus the opening does not hurt the drag coeficient in the car, it more than likely lowers it if anything
#36
If you wantsignificantly better aerodynamics and better cooling of the car, then complete revision of everything forward of the leading edge of the hood is in order.
In stock configuration, the bumper cover is only a little better-shaped than a brick, which it somewhat resembles. The pop up headlights are oversized and protrude into the slipstream, so make pretty good speed brakes and excellent radar reflectors.
Better to have designed a face for this car resembling the Carrera GT or other late Porsches, with conformal headlights/clear covers, as well as a proper vent for the IC cooling air.
#38
Drive-by provocation guy
I thought the drag coff. of the 951 frontal area was one of the lowest in the industy...like .32 or something???
#39
It was one of teh lowest when designed and I'm sure there are lower now. I would not describe it as brick like though. The front of a 67 Camaro is brick like....
Cutting up the front of the bumper will not improve aerodynamics nor will it help cool the intake charge (intercooler).
#40
sorry, but i am really not a fan of the mesh. it looks like an afterthought. i can alse agree w/ what several people have said re: cooling, only a reverse-duct in the hood (aka some way to create a low pressure area to pull air out from the IC / rad) will help cooling. cutting the factory bumper won't - or porsche would have done it when they sold the car
#41
there is no effective use of this. It won't provide any real extra cooling. You added drag for personal taste. Probably added lift as well... Way to out engineer those guys who spent countless hours in a windtunnel.
mesh doesn't belong on cars, it belongs back on the shelf at Home Depot.
#42
Opinions, opinions, the CD is .33 by the way, .36 for the 944 .31 for the new Cayman S and .30 for the boxster for all those who don't know. When Porsche engineered it, they were also keeping in mind that cars in europe also carry tags up front, just a little wider and thinner, so the design had a lot to do with that issue, plus the owner of Promotion is also doing the same design but without the mesh, he is going to have a bigger intercooler, so as long as he approves it, that's all that matters, since it is his design originally...
#44
"I thought the drag coff. of the 951 frontal area was one of the lowest in the industy...like .32 or something???"
Well, the drag coefficient of the WHOLE CAR may be pretty good, but the NOSE itself ain't so hot. Anytime you put recessed lights, lumps & bumps, nooks & crannies, and various sharp angles on a body that goes through a fluid, your'e gonna get more drag than optimum. After all, if it were so great, why did they modify the nose of the 968, or make smooth and flowing lines on the newer 911-series and Carrera GT cars?
And, did you ever see a modern airplane (or especially sailplane) with nooks & crannies in its nose? This is a critical area for drag avoidance, and our cars could stand some improvement, including proper venting of the IC cooling flow.
