Exhaust flow question with diagram
#46
Originally Posted by RKD in OKC
Best turbo exhaust gas exit...
A horn is the best, like the end of a trumpet or trombone with the OD increasing from the turbo outlet. Without any pipe or a pipe that is bigger than the turbo outlet itself turbulence is created that blocks the flow out of the turbo and causes more backpressure than a pipe that is the same size as the turbo outlet.
Blowing this turbulence down any pipe will only increase the pressure drop.
#47
When Janspeed (well respected tuning company here in the UK) were developing the exhaust on my car for essential styling they found putting a front box into the system increased the power and reduced the volume so louder isn't necessarily better (especially if you have track noise limits to beat),
Tony
Tony
#48
Wes at Lindsey Racing did two dyno runs with his car, one with the LR 3 inch and another with LR 4 inch. If I remember correctly there wasn't as much of a big gain in HP or Torque as much as it moved the powerband 500-700 rpm lower. I think the runs were with a Sport Turbo and not the big honkin' Super75.
And to answer another post, yes it was with different mufflers. But the 3" muffler they used is actually consindered to be better than the 4" muffler they used.
