L/R knock sensor harness question
I just received my L/R knock sensor (& injector) harness (very nice BTW) and had a question regarding the “bare/ground” wire that connects to pin#12 in the KLR.
What is its function?
The “black to KLR pin#11” and “clear to KLR pin#13” wires “pin out” to the knock sensor connector plug but the “bare/ground” wire that connects to pin#12 in the KLR just ends inside the harness and doesn’t “pin out” to anything
TIA
TIA
Its the shield wire. Theres a braided shield around those other two wires, but our knock sensors dont have a pin for them due to no "internal" shield inside the sensor itself so no pin on the knock sensor end.
Originally Posted by 951Boost
Brian, thanks for the response, I guess that it's just another case of German over-engineering then.
knock sensors are like microphones so the signal is very weak and low powered. Without shielding it wouldnt work.
Originally Posted by por951turbo
How hard was it to replace the harness? Did Lindsey send instructions.
I did take a quick look at the harness and noticed several pins/tabs on the ends of the wires. I haven't removed my old harness yet, so I don't know if those wires are home-run all the way to the ECU, or if there's simply another connector in the engine bay that we swap the pins out on. I'm hoping it's in the engine bay, because I really don't want to have to fish all that stuff through the firewall...
Rennlist Lifetime Member
The leads from the replacement knock sensor terminate inside the KLR connector (LR Injector harness is same, terminates inside DME connector).
The terminators on the replacement harness replace everything, the wire and the pin. You'll need to remove the pins from the various pin locations and replace with the new unit. Its quite simple once you get your DME and KLR connector off.
On the injector harness the wires do go all the way to the ECU. I put one in my dad's car about six months ago. My only complaint about it is everything is plug and play except that one black wire that goes to the KLR that you have just splice into another wire for. Everything plugs in so cleanly except that one wire.
I got the harness replaced, I was asking how to test the knock sensor now.
I believe I have seen a procedure in FSM involving a multimeter or oscilloscope. I can look it up for you later on tonight. Clark's Garage doesn't have a procedure.
