Cometic Oring Pictures
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
OK folks, here are the pics of the new Cometic Head gasket I promised. I like the concept and execution. The ‘main’ part of the gasket is just there to hold the O- ring in place and seal the water and oil areas. The cylinder sealing is handled by the O-ring.
The specs on the O-ring are pretty cute – it is silver coated with an internal inert gas pressure of 600 psi.
Enjoy the pictures…
BTW - the engine in the pics is a 105.5mm bore. These headgaskets will work from stock size up to 106mm.
Chris White
Enjoy the pictures…
Chris White
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
No groove – it has to be used on a flat surface. If you look at the installed pic you can see one cylinder has the oring in place and the other does not. The rest of the head gasket holds the O-ring in place. The O-ring is a precision fit inside the cylinder hole in the head gasket.
If your head is already O-ring the conventional way you can leave the O-ring in place and skim cut the head.
The only draw back…the head gasket only comes in .051” thickness. Not a big deal, especially if you are sleeving because you can spec out the piston height to match. For standard block engine you will lose a little compression. (not enough to notice).
The other drawback is it will cost somewhere around $250…
Chris White
Chris White
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Originally Posted by J Chen
Does that mean that the gasket is no longer
the MLS variant Chris ?
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Are the size limit – the largest O ring is a little over 106mm ID, so it is pretty much a 106mm limit.
They are available now, at least I can get them anyway!
Chris White
Chris White
Thefu
Chris White
What other fun stuff is brewing?
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
I checked with Cometic – the final price on the gasket is $258.50 and they do have the parts in stock now. If anybody is interested let me know, whitechristopher@earthlink.net
A disclaimer is needed here – While I really like the technology in the gaskets I have not done any personal testing yet – there is a fresh foot of snow outside, I don’t expect to really test one until my first track event in May. I may book some dyno time before then but I don’t really feel like a part has been tested until it gets a couple of track days of run time!
Chris White
Chris White
Chris White
Chris White
re-read Chris' disclaimer. This thread has shown some bandwagon action. It's worth having Chris' additional feedback after he has had the chance to run the **** out of one or two of these, before jumping on them...but it's your cash.
Originally Posted by ehall
ALL HANDS!
