Wide Fire Ring Headgasket modified
Rennlist classifieds has an ad for a Wide Fire Ring Headgasket modified
I called and asked what the modification was? They told me all they do is add additional holes to the gasket to aid in cooling they supposed to have copied the Turbo RS headgasket design.
Does anyone have any experience with this modified gasket?
Thanks,
Thanks,
Would you be so kind as to tell me how this works? More holes in the Gasket loweres the temperature? I don't understand. Maybe I'm missing something here. Adding more holes will lower the block pressure which could raise the temperature in the Block. Adding more holes will lower the volume of water passed up around the #4 cylinder and increase the chance of pockets of air trapped or not purged out towrds the outlet in the head. Isn't known that the stock Gaskets seem to fail around # 4 Cylinder. We want more water there to stop the hot spots from creating. Won't the extra holes work against this?
Does it really improve cooling or is it just some more marketing BS that’s what I am trying to find out?
