Vitesse MAF and K27/8 Install Complete !
Well, the Vitesse MAF and my K27/8 are installed and all the obvious bugs are worked out. The power is absolutely amazing - it is night and day compared to stock.
The challenges included:
- Battery decided to die during the build-up and threw me for a loop - new battery fixed this one
- Loud squealing noise under boost had me expecting the worst - turned out to be a loose clamp and a boost leak
- Bad stumble on boost - thought it was a lean condition, but turned out to be leaky Magnacore ignition wires
The most frustrating part of the install is making the Forge BOV fit. Mine still doesn't fit to my satisfaction - I need to rig up some other hose setup.
I'm still running the blank map in the SMT6 while I get used to things. Thanks John at Vitesse for an excellent product with excellent instructions and support !
Here's a couple of pics...
You guys need to cut the side port of the clown-like long Tube and lay the unit down parallel with the upper boost tube.
The 90 degree rubber hose now connects the bottom Forge to the turbo intake pipe.
Now it wont dent your hood any further and the coolant resy will hold it really snug.
ST you mean cut off/shorten the side port of the valve? The means cutting off the swedge.
Wont the hose blow off under boost?
Perry you have different hardpipes.
The connector for the CBV on the IC pipe is closer to the throttlebody on the stock IC pipe.
I read somewhere that it should be as close to the TB as possible, but it didn't explain why.
Swap the hoses and invert the BOV opposite of mine. (port towards the throttle body). This way the outlet uses the 90 elbow and the straight section connects the IC pipe and inlet. Should fit.
Placement of the port on the pipe is not a huge deal, as long as it is after the IC.
Interesting... I guess my J pipe has the port in a different spot. (it's an SFR pipe) I was able to get the BOV in place with the factory pipes.
Can you get the pipe roatated any to help? If not, it looks like you need to hack up the port on the valve or the pipe in order to get it in there.
ST, thanks for the tip. I trimmed 1/2" off the BOV and fitted it the other way around. It's a much better fit. The hose on the bottom could have been a little longer, but it will work just fine.
