Boost Gauge ?
Boost Gauge ?
I bought a defi d-guage and was wondering where i should splice into to get boost pressure? I know the easiest way to tap into would be the klr line but ive heard its better to splice into somewhere around the fpr. What is the most accurate reading? Thanks for the help.
Originally Posted by kevincnc
My intake has two banjo bolts- a single and a double. I bought a double and replaced the single, so no lines had to be cut.
Originally Posted by zerMATT951
Or, even better - talk Laust into making some more of his 5-port vacuum manifolds
i believe it's more accurate than the KLR line because the line itself is shorter (shorter = better). the piece is a soft rubber T fitting. you can buy one here;
http://www.partsamerica.com/ProductD...rtnumber=47415
and this has been discussed in detail already. thread is here;
https://rennlist.com/forums/showthre...ighlight=boost
The pressure at the manifold and at the KLR line have to be the same. If there is a pressure difference between those two points, then elementary physics says that air will flow from higher pressure to lower pressure to equalize the difference.
