Zeitronix Help!!
#31
Drive-by provocation guy
ok cool.
Yea, it seems the idle is fine. and I will work on the others. I guess I will get it all set, then see how adjusting the ACELL effects things.
#32
well, getting used to it.
Should all HIGH tuning runs be done in 4th gear?
How lean can you go in the MID to help spool up?
#33
#34
Ok.
Yea, I had it really rich at first to be safe and have just been dialing it back little by little.
until I now noticed I am rolling off boost up top, but that is another issue I guess I will have to address first before I can get an accurate tune.
If you stay in closed loop, the computer takes over and does not let you make adjustments correct??
#35
'I ran 13.5:1 on 100 octane by mistake recently "
Wow, that is only a little lean and with the 100 octane should have covered that. Are you running a lot of advance???
