Help! Rear end whine
My '86 with LSD has a high-pitched, variable (weeoooweeoooweeooo etc) whine audible only on the road with the car warm, generally above 20MPH, minimally louder recently. I've checked everything I can think of including parking brake, CV's, brakes etc. I can shut the engine off and still hear it, coasting. No change with slalom turns, not a typical bearing growl. My next thought is to replace the diff oil in case I got the wrong type last change. Any thoughts? Can't reproduce it in my garage, recently replaced the fuel pump with an 044, no difference.
RADS
Zermatt Silver, Vitesse 2, single owner from day 1
RADS
Basic Sponsor
Originally Posted by TurboX
You might have low trans oil. My 5th gear has a whine, im not sure what its from.
Basic Sponsor
And now you know why i never post in the 944 turbo section
Back to topic. My 2nd 951 had a similar whine when I was on the fwy and let go of the gas, but I replace the tranny oil with red line and the whine was gone.
Thanks, guys. Snappy, I backed it up this morning and didn't find my ex. Tomorrow I'll check the tranny oil and probably replace it. I think there's synthetic in it at the moment, and a number of people at the track have told me they don't like synthetics for the rear end.
RADS (currently in Estero, FL for the winter)
'86 Zermatt silver, Vitesse Stage 2, single owner since June 10, 1986
Not knowing what it really sounds like, I'll throw this out as a possibility.
Tire noise. My Kumho Ecsta Supras began making so much noise that I replaced my rear wheel bearings, my mechanic even thought that's what it was...
Good luck.
Good luck.
Final answer:
Up on the lift with the wheels turning at about 60MPH, the left rear wheel proved to be the source. The tranny oil was good, filled to the top, and review of my old service reconds showed Sepco, left that alone. A defective, scored left rear hub proved to be the culprit. Who'd guess?
RADS
Zermatt Silver '86 951, Vitesse Stage 2
RADS
Since you have it solved, allow me to add one thing.
lart told me that when he doesn't oil his tranny just right, sometimes he/she will whine all night as well.
