Compressor Surge/WG staying open???
Drive-by provocation guy
Just had new Tial installed and noticed on boost sometimes I get the "normal sounds" of the turbo spooling....coming out of the tail pipe when I let off or between shifts????
I have the WG dump to atm and it does not sound like it is coming out there. Sounds like from the back of the car; almost if the muffler had a big hole in it, but it doesn't.
anyone???
anyone???
i dont completely understand this.....explain better?
you should get the regular *kssssssh* when spooling, then an extremely loud "BWAAAAAAAAAAAAAAAAAH" when the WG opens at WOT with the dump to atm.
how can you hear it from the back of the car if it's not moving?
"you should get the regular *kssssssh* when spooling, then an extremely loud "BWAAAAAAAAAAAAAAAAAH" when the WG opens at WOT with the dump to atm. "
Correct, but it seems to be coming from the back of the car, like from the tailpipe/muffler and only when I let off and/or in between shifts.
"how can you hear it from the back of the car if it's not moving?"
this is when the car is being driven.
