Any experience with cams?
#32
jimbo1111
You did the right thing by calling John Milledge.
And you can make a ton of power on stock valves.
I made 401RWHP using a JME head/cam with stock valves on a 2.5L at 17psi (415RWHP at 18psi)... with other modifications.
Something to note... installing larger valves only to have them packed up against the combustion chamber wall is like taking 2 steps forward, and 1 step back. The valves become shrouded big time, killing a lot of the benefit of the larger valves....
But... on a larger bore engine (104mm-106mm), you can really take advantage of the larger valves since you can open up the combustion chambers to unshroud the valves.... which is one big benefit of doing a large bore engine.
TonyG
TonyG
#34
your all too damn keen to spend get the NA cam i found it a great uprade my car makes heaps more torque at preboost and any boost and its definatly the ultimate cam if you have a moddest turbo i would say the NA cam is the best cam up to 430hp it cost bugger all so you can spend your money on big exhuast and fancy turbos wich are a proven thing . there are drawbacks to massive cams no drawbacks to massive exhuasts .
#39
More exhaust lift so breaths better is the mantra
Intake opens 1 degrees after TDC
Intake closes 49 deg. after BDC
Exhaust opens 43 deg. before BDC
Exhaust closes 3 deg. before TDC
"new" N/A cams values:
Exhaust opens 47 deg. before BDC
Exhaust closes 1 deg. before TDC
2.7L N/A has the same values
So, only the exhaust side lobes are different.
#41
i had different numbers cant find them at presant but as i remember the exhuast duration goes from 219 up to 228 and inlet from 224 to 228 and a web cam is about 232.i just got a report of the web cam making a midrange torque loss with a standard tubo and almost (motec)standard car
#45
No,early N/A cams are the same as the turbo cam. If want to stick with a Porsche cam then go with the 85.5 later N/A cam which has more exhaust duration.
If you want to go with an aftermarket cam though there are many options available.
