Stuck boost gauge?
Legend Killer
Was out for a drive tonight and noticed the boost gauge is constantly stuck at the 1 Bar position. I still have all the boost so I dont think its a leak anywhere. Do the gauges go bad? Any idea how to fix?
whack the top of the dash real hard ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
but seriously. most of the times when the gauges go wonkey it's due to the connections going bad. pop the cluster out. and loosen the nuts/screws that connects to the mount points and use a very fine grit sandpaper and clean them up and screw it back in. I would try that first, if that does not work then take the back plastic track off and look at the 3 internal points those gauges are extremely simple build, could be why thy are not all that accurate, I hacked it a tad so it gives me true numbers "-atmosphere". the chance of them completely failing is slim, I do not think I have ever seen one that was not fixable with tinkering with it.
KLR line is off or broken. It will read 1 bar (atmosphere) constantly when it's not plugged into the intake.
Does the gauge move to 1 bar when you turn the ignition to run (on - not started yet)? If yes, then it's not the gauge, it's the line to the KLR.
Dal.
Dal.
