New Rear Coilovers - 968 style
Has anyone tried these rear coilovers from San Diego Motorsports?
http://www.blackforestautomotive.com...Suspension.htm
i've got an older version with a similar spring, but mine are adjustable for rebound and compression. they appear to be a stock koni shock only painted san diego motorsports red
Originally Posted by JoeN951
for $295 more you can get these...
http://www.paragon-products.com/prod...rearcupkit.htm
Originally Posted by jturbo
Do you know if the koni shocks they use are the "Sport Yellow" shocks?
"Awhile back I had the Paragon Koni sport cup rear coilovers on my 951, with the minimum 80# springs. Even with those adjusted as low as possible, the car raised up 1" from stock! Now I'm using 968 M030 rear Koni's w/ 200# rear springs (shorter than the 80# at least) and it sits at about stock ride height (maybe .5" higher). From my experience, it looks like ANY rear coilovers will require indexing the torsion bars for it to sit properly."
sorry, but this statement wins the "No ****" award of the month. You CANNOT adjust ride height beyond that facilitated by the eccentrics without either reindexing or deleting T-bars. Period. Any reasonable effort at a search here, or just taking the time to read Paragon's site, makes that absolutely CLEAR!
Any 944 or 968 rear shock will work on any year 944 or 968 from what I understand. The same cannot be said for the front struts though.
